evinrude 110 vro v4 charging issues
Procraft1989
I am having charging issues. It seems that it will charge sometime but other it will not. I have been told that there are 2 regulators and one maybe bad. How do you test them?? Also the tach will does not seem to work when when batt is low on charge. Any help would be great. Thanks Ben
bonitoman
Re: evinrude 110 vro v4 charging issues
Sounds like your rectifier. Its about $120 for the part. Sits on top of the engine behind the flywheel.
Procraft1989
I am mechanically inclined, so would this repair be something I can do or should a boat shop do it?? Do you know where i can find the replacement rectifier?? Ben
bonitoman
It will take you 5 minutes to change. It has a few electrical plugs and 5 or 6 hex screws that you remove. It will come with a new gasket. You can pick one up at an OMC dealer. Some call it a rectifier/regulator. It sits directly on top of the block
Procraft1989
if shorted would it also drain a batt? I charged the batt for a good part of the day and after doing some testing and eating dinner it did not have enough power to tilt the motor. The batt is brand new and a base charge was put on the batt before it was used. Thank you for your help. Ben
D
DJ
Guest
Make sure the negative battery terminal on the engine block is clean/tight.<br /><br />Remove it and clean it, don't just inspect it.
Procraft1989
Is it normal for the front section of the motor to have what appears to be gas/oil mix all over it?? The whole carb set up is covered in fuel. I dont' even have the first problem fix and now this damn i will never be able to go fishing at this rate
D
DJ
Guest
Procraft,<br /><br />Some "misting" is normal from the air silencer.<br /><br />I can't see it, but I think you have a fuel line leak. Look on the pressure side of the fuel/oil pump. Pinhole leaks can create quite a mess.
Procraft1989
that sounds like what I was thinking Like I said Im no boat mechanic I have only worked on cars and still learning about this stuff. Thanks for your help. Ben
D
DJ
Guest
Procraft,<br /><br />When it gets down to basic diagnostics, it's no different.
Procraft1989
I have been checking the batt volts all day and since I clean the terminal off like you said the batt has stayed at full voltage. thanks for the tip I will check it out tomorrow with a dvom while running and see if it will charge now. What is standard operating voltage while running through the batt?? I know a car is around 14v but not sure on a boat. Ben
Procraft1989
what sound the operating voltage be when the engine is running?? Ben
Silvertip
Honorary Supreme Mariner
Between 13.5 and 14.5 volts give or take a little on the high end is good.
Procraft1989
it still not charging. I ran it today with the earmuffs on it and it started to drop off from 12v to almost 11v when i shut her down. Does this still sound like the rectifier/regulator??
