evinrude 115hp starting and runing problems
matthew1
My outboard 1985 evinrude 115 starts up great 90% of the time. 10% of the time it takes 3-10min of motoring to get it started. Runs great 90% of the time 10% of the time it acts like its running rich, bogging down then it will just run like a top any body have any helpful info
Thanks Matthew
ezeke
Re: evinrude 115hp starting and runing problems
Many times that is caused by water in the fuel. Do you have water separating fuel filter installed?
SparkieBoat
I agree sounds like bad fuel, or possibly a coil/power pack going in and out. I recommend making sure water is not getting into fuel and then new Champion plugs, also check plug wires, those cowls are know to hook the plug/coil wires, crappy design if you ask me, have to be so careful when installing the cowl on OMC V-4s
matthew1
I will look again but I quite certin there is no water I was leaning to an electrical problem Thanks
matthew1
Is there a positive way to check the coil packs
it's coils, and power packs, not coil packs.
No real good way to check power pack that I know of (just replaced my power pack myself). There are plenty of articles online here to check if coils are good just do a quick search.
If the power pack goes out and your coils are old, you might as well change the coils too because theyll probably go out soon as well.
emdsapmgr
When the engine starts to run badly, the ignition system could be dropping a cylinder. If you have an inductive timing light handy at that exact time, put it on each of the 4 plug wires and look at the flashes from the light. You will be able to see weak spark and misfires. That engine has two power packs, one for each head. You can swap them to further verify spark capability and they can be replaced individually.
matthew1
Thanks a lot for the trouble tree I can work with that and thanks everyone else for the help
matthew1
Luke sorry for the wrong term I have not worked on to many boat motors I am a Master Technician for a S76C+ helicopter
