Hello, here's my question. Underneath the carb cover is 4 small T's that go to a fittings between the carbs. What are these fittings and what do they do? I was told that these fittings were check valves, is this correct? My engine runs fine but dies in nuetral or low RPM in gear. Always have to start it up using the idle lever then slam it into gear. Thanks in advance.
