Evinrude 135 HP v4 timing question: IE how to without a wheel.
kevin88
You may have this covered in a FAQ somewhere but I don't have time to research for the correct answer.<br />I have an 1974 Evinrude 135 HP v4 (135489b) and I have to set Maximum Spark Advance. I do not have access to a wheel and tank setup but I can take this to a lake and test on a trailer.<br />My book reccomends 4 deg at idle and 22 deg at 4,800 RPM and a max RPM of 5,200.<br />My question is this: If I set the timing while the boat is tied to my trailer should I set it to the specified 22 degrees or should I shoot for a lower number because of other unknown variables? If so then what number should I shoot for? I'm looking forward to putting this beast back together this weekend, timing it out, and giving it a good run. Thanks for any input.
ddbyrd3
Re: Evinrude 135 HP v4 timing question: IE how to without a wheel.
If you click on the search tab, you will find the answers you are looking for, type in WOT timing, it took you longer to type your post then to do a search.....<br /><br />And no I did not intend that to be sarcastic....
kevin88
I think the whole dilemna about time that I was referring to was sorting through the 256 matches to find one that just might have an absolute answer to my exact question. <br />I'm wondering though how much time it took for you to type a reply when anyone could have spent that same time helping... I am sorry.
ddbyrd3
OUCH!!!!!! man I said I wasnt trying to be sarcastic.... <br /><br />The experts here on this board, and I am not one of them, suggest that you static time your boat 4* short of the suggested max WOT timing. The electronics on the motor make up for the remaining 4*....<br /><br />So if your max is 22* set your timing at 18*.
ddbyrd3
web page<br /><br />This is my first time trying to attach a link, see if it works.... just input your timing numbers...
Boilermaker
Keven, the Key word about timing as suggested by DDBYRD3, is STATIC timing! That is timing with the Sparkplugs out & spinning the engine with the starter!<br /> I am NOT one of the outboard engine experts here>>>I just learned this myself this year>>>Below discribes how I set my timing & it works great. <br /> You can set your timing on the trailer AT THE RAMP. Back the boat into the water enough to cover the water pickups & make sure you are secure on the trailer & the tow vehical is secure.<br /> IF you can't get your rpms up near the recommended rpms, try tilting the engine up a bit & letting the prop vent a little. DON'T run without getting cooling water into the engine. <br /> SET timming to factory specs.<br />By the way, even after setting the timing by the static way as DDBYRD3 suggested ( a very good way to set timing) , I know most experts here recommend verifying timing by doing it like I did, or running out on the water with the hood off & hanging on.<br /> I just think its to dangerous to try timing while running 40+ mph on the water, inches away from moving machinery!!!<br />Good luck<br /> :cool:
kevin88
Thanks all for your input. I have found the Joe Reeves method of timing but don't have access to a spark plug tester. And on a nearly empty budget I don't see one in my future. <br />I think I will try the boat launch ramp trick this weekend... I found that someone suggested putting a little white paint on the timing mark too. I think I'll try that, set it at the ramp, and then do a final check on the open water. After doing everything the wrong way and paying the price I want to make sure that my timing is done correctly without putting my motor at risk.<br /><br />AND P.S. : I apologize for being grouchy. Two abcessed(infected) teeth at the same time will do that to ya. It also limits my ability and time. I hope you understand.
Basscat 1
Kevin, you can make yourself a homemade spark tester like I did for next to nothing. Here check it out. web page <br />As Boilermaker says, you still need to test it on the trailor. Usually 1 turn on the wot stop will change the timing by 1*.
