fishdog4449
- Joined
- Jul 16, 2007
- 462
Hey guys,
Evinrude 140 bubbleback crossflow here, 1984 year. I went to start the motor for the 1st time this season. She fired up after several cranking and priming sets. Ran for a few minutes then pulled the plugs to inspect, the stbd (looking fwd) bank of cylinders has clean plugs - I mean CLEAN, no whitegrey water/oil mix, nothing. The port side plugs look like what I consider normal for a 2 stroke, perhaps even a little too dirty.
A little history - I bought this boat a year ago. Haven't had time between school and sea (Marine engineer in training) to do much work on her. I had her out once last year and the 140 wouldn't get past 2k rpm or so. It revs up fine with no load. I tried 3 different props, adjusted the motor height, and checked the boat for soggy foam/water, all of that checked out. So I rebuilt the carbs, new primer bulb and fuel pump, adjusted Spark advance and carb link n sync. Compression is 120 120 125 115. I did notice that the p/o had removed the thermostats (which I put back in along w/the relief springs). Then I had to go back to school so I winterized the boat.
So my question is, where should I go from here? How would only one side of the motor be getting fuel? Also, what is the function of the small vacuum lines running from the transfer covers to various spots on the intake/crankcase?
For the OMC gurus, I've attached a picture of the plugs one from each side (each bank looks identical) and a video of the motor running. Picture was taken immediately after removal from the motor.
http://www.youtube.com/watch?v=zBdZjdLv_6E
