Evinrude 15 HP 1979 How Do I Remove Gear Case
RasmBTop
Hello,<br />I was justwondering if anyone knows howto remove the gear case on the evinrude 15 HP from 1979, and also if anyone knows how to attach the drive shaft.<br /><br />Thanks,<br /><br />Rasm
Bear
Re: Evinrude 15 HP 1979 How Do I Remove Gear Case
You need a manual. There is a link below. The maual will pay for itself in time. :) <br />Good luck!
Joe Reeves
RasmBTop..... Remove the lower unit bolts that are obviously retaining the unit. Drop the unit slightly so that the brass shift connector (at the front of the unit) is visible. Remove the top 3/8" hex head bolt from that connector. The lower unit will now drop off.<br /><br />Removing the water pump will allow you to simply lift or lower the driveshaft up and out of the lower unit, or back into it.
RasmBTop
Thank you very much for your help.<br /><br />Rasm
