Bump_Out_Another_Thousand
Thread starter- Joined
- Jun 6, 2010
- 5
HELP! Please!
Usually, I don't ask for help, I just give it. However, this has me stumped. I an exchanging my old lower for a used replacement, due to a minor mishap that happened a few weeks ago. When I get the replacement, it has the XL shaft, and I need the L shaft. So, since my old shaft is fine, I set out to replace them. Here's where I am confused...
I removed the prop shaft cage, the reverse gear, and the pinion gear nut. Everything (impeller, plate, ect) is stripped from the shaft. However, I cannot get the shaft out! My understanding is that after the pinion nut is removed, I should be able to pop the complete shaft out of place by hand.
I am scared to try any grip-and-hit tricks, because the replacement has a 2-pc shaft, and I need both peices out, as I am putting in a one-peice. If anyone can help me, PLEASE do. If you need further info, PM or call me 859-757-9767.
Thanks,
Chris
Also, I forgot the important info... The Powerhead is a 1985 Evin. 150 XP, and the lower is a 1992.
Thanks,
Chris
