Re: evinrude 150 outboard spark problem
Cant imagine why you would lose spark from running out of fuel.Do you have a spart tester ,or are you checking with plug or what.The ball should go soft after you crank,the fuel lines are likely full of air,often the best way to purge it ,it removing the hose from the eng,then squeeze the ball ,have you finger over the hose end as the ball expands,what that does is allows the ball to suck fuel,not air,do it a few times til you get gas,then reattach ,and squeeze the ball to fil carbs,when you tested for spark,did you have all plugs out to allow the eng to turm a fast RPM,if not you will get no or little spark,my guess is ,once you have fuel up to the cylinders ,and as long as you get a good crank,you will fire.
