Re: Evinrude 150 prop on 120 inboard
What matters is not what brand of drive or lower unit a prop fits; it's the specs of the prop!<br /><br />If it fits YOUR drive, you can use it. If the hub fits the gearcase & shaft and the thrust washer fits 100% you can use the prop. As far as I can see from catalogues etc. they are different (as one could expect!)<br />If it has the specs that you need, you can use it without risc of damaging your engine.<br /><br />In your other post you state that you are on the lower limit of the recommended rpm range at wot, so you should not go higher in pitch than your current 17".
