jdlloyd_iboat
- Joined
- Jan 15, 2006
- 52
I have a 1988 Evinrude 150hp which I have run for 2 seasons without a problem except for the replacement of a thermostat. I do not know the history of the impeller (water pressure has been good) but I am wanting to replace it this season. I am not too familiar with maintenance on outboards but am mechanically capable of performing the job, have a manual and the parts. My question relates to a fear of removing the bolts! I easily sheared a bolt off the water pump housing on this motor which indicated that those small bolts were fairly well corroded and had not been removed in some time. What should I be concerned about in removing the bolts on the lower unit? Can I exert a good deal of torque withut fear of shearing one of these bolts? Are these bolts pretty robust? Does it depend on length of time they have been in and if they were sealed with proper anti-seize? I eventually will need to replace the impeller; should I be pre-emptive or should I wait until it's absolutely necessary?[colour=null][colour=null][colour=null]
