1994 V6 60 Deg. Evinrude 175 Hp.
The starter drive gear seems to spin free. this turns the driven gear that spins the pinion worm shaft and in turn should make the drive pinion assembly ride up the pinion worm shaft and engage the fly wheel.
my problem is that the drive pinion assembly just spins and will not ride up the shaft to engage the fly wheel. I've taken the assembly out and checked the moving parts and they seem to work ok in my hand and I also checked it against the shop manual drawing and everything seems to be there and working. but when i put it through the test with ignition switch every thing just spins without engaging.
I was wondering if anyone has any idea what can be causing this to happen. and if so what can i do to fix it.
I included 2 pics.
Thanks
I included 2 pics.
Thanks
