Evinrude 1916 model D
Math.?.
Re: Evinrude 1916 model D
Hi all,
I am actualy starting rebuilting the motor and i would like to know if the crank pulley on top of the fly weel is original or not?
Math.?.
Yes thanks..
It was maybe a motor that was been modified from the normal crank start to a cord start.
Do you know how can i fix the coil for it?
HighTrim
Freak'in awesome! Love it, thanks for the pics.
HighTrim
The coils can be rewound if you can find someone skilled enough to do it. Magnetoparts.com may be able to.
Im assuming your secondary is shot?
Can also try email Doug Penn, google him. He helps alot of us out with the older coils.
May also be able to modify it with a newer coil. Can you post a pic of the coil you have?
Math.?.
Finally took off the flywheel and realized there is no coil under it :O
I will be obligated to run it on batteries...
Do you know where can i buy them?
Here is a picture
HighTrim
I would email Doug Penn as stated and ask him for a hot mag plate. It will come ready to go.
Math.?.
Bah....
I may run it on a standard car coil and battery.
Math.?.
Anybody have an idea how i can finaly run it?
Can't find any coil or nothing....
boobie
I used to work on those Hus-Ski's. They would go any place where the Ski-Doos got bogged down. Good old machine.
HighTrim
You could modify the coil with the new Universal Coil on the original lamination. Did you try Doug Penn??
kodibass
google dough penn ( dough penn.itgo.com) he has everything you need for your motor. (everthing!! He is very reasonable & a joy to deal with.
Math.?.
Yes, i already sent him a message and he told me he didn't have anything to help me...
I found this diagram on internet, do you think it could work on my motor?image.jpgimage.jpg
Thanks
Mathieu
Chinewalker
Yes, using your existing points, a buzz-box set-up would work fine. I was running a battery ignition motor just the other day, a 1928 Elto Quad!
