cropduster21
Thread starter- Joined
- Oct 13, 2008
- 24
I just bought this little motor yesterday. Estate sale. The man selling said it was his fathers and it would probably need to have the carb cleaned and a new impeller. I'm pretty handy with motors so I bought it. I need an aux motor for my center console boat.
I'm working on it today. The motor fires when gas is injected into spark plug holes. I dont have a gas tank yet but I tore into the carb and squirted carb cleaner through the jets. They look clean. bowl was clean. cork float doesnt look to good. The bowl was so clean I guessed someone had it apart before me. I took the fuel pump off to see if the screens were clogged. Everything looked clean. NOW the problem. I think someone had been into the fuel pump before me. The diaphram looks like it has been repositioned someway. There was only one little coil spring under the diaphram, and there are 2 small stud to set the spring or springs onto.
My question is. Are there supposed to be 2 springs under the diaphram? one for each of the 2 studs? if not which is the correct stud for placing the single spring. How much is a fuel pump kit and where can I find one. Also a new float.
Thanks for your help!
