Hi,
I've been working alot on this motor of mine. I've changed the impeller, spark plugs,repaired the electric shift and did a total carb cleaning.
I have a big issue now. Well the issue has always been idling under load. It was fine when I was simply putting the motor under muffs, but I set the idling higher on it so that under load it would idle fine. When I did the carb cleaning I noticed that the middle idle screw was missing the needle. When I checked inside the threaded hole I spotted the needle. So I gently tapped on the carb to let the needle fall losely, but it didn't budge. Even with spraying carb cleaner it didn't move at all. I'm at my wits end on that thing. How am I suppose to grab that thing, it's impossible to get it with longnose pliers, anyone has had the same issue?
