Evinrude 1977 75 Hp 75743s NO SPARK please help
Tboner7864
Hello everyone Finally got the motor installed and hooked up changed the water pump and got it running. The day we were going out to test the motor I tested it right before going to the lake it fired up and run for 20 seconds and died. I had it running and Idling the day before for a good 15 mins everything looked good. Then the next day it started then died, checked the fuel then I check the spark and sure enough nothing just all of a sudden no spark please help!!!
Tbone
boobie
Re: Evinrude 1977 75 Hp 75743s NO SPARK please help
Disconnect the black/yellow wire from the power pack and see what happens.
Tboner7864
I disconnected the wire and removed the spark plugs and hooked them up and tested still no spark
boobie
Sounds like a bad power pack. Go to cdielectronics.com for trouble shooting procedures.
Tboner7864
Thanks Boobie that is what I thought
