I have a 1981 Evinrude 9.9 model E10RCID outboard I'm having some trouble with.
It starts just fine and stays idling just fine however under load it seems to only run on one cylinder. When the throttle is wide open it gets very jerky and you can feel/hear the other cyl kick in then shut off then kick in etc. Making the ride very jerky. Also when you let off the throttle from Wide open throttle, even just a little bit it just goes right back to idle regardless of where the throttle position is. I then have to turn the handle down to idle speed in order to 'reset' itself so to speak. When I do that it runs just fine and I can increase speed enough to get up stream... slowly... If i try to get on plane again the same thing happens.
It idles fine and putts up the river fine but when I want to get on plane it gives me the issues listed above.
Is there a chance the ignition module could be the culprit? or Would that happen at all times not just under load?
The plugs are new, I had the plugs out and tested by cranking I was getting spark on both. The carb is clean and has all new parts. It's not over heating and again it starts up first time every time w/o issue and stays idling w/o issue.
Any idea?
Thanks,
Anthony
Any idea?
Thanks,
Anthony
