riverdog01
- Joined
- Apr 21, 2010
- 48
Hi, this will be just the first in a string of neophyte questions on my mission to rebuild this engine. Your patience and help appreciated.
1) can I just drive the lower seal out of the exhaust housing with a screw driver from the other side or is there a better method or should this seal be kept ? Pic below, seems everyone says replace as a rule
2) the water tube is stuck pretty good and the grommet is melted, would you just heat this up and pull it downward or is it designed to be installed/removed from the top ? Better way ?
Removal of these things is not explained in my service manual for my outboard. (maybe I'm expecting too much !)
Thanks
Thanks
