Evinrude 1988 25hp Manual Primer Problem
artherm
Today my trusty Rude would not start. We started trolling from the dock, with the engine tilted, and did bother to start at this time. Four hours later, I lowered the engine, and tried to start manually. I pulled the primer several times, however, I do not believe I flooded the engine. It would not start. I replaced the plugs, and it still would start. We returned to the dock with the trolling motor. When I returned home, I disconnected the fuel line, and popped the snap ring from the primer and pulled it apart. Several small black, plastic appearing particles washed out. I sprayed the primer housing out with WD40, also sprayed the primer shaft to clean, reassembled. I re-routed the inlet fuel line from the carb. bowl to where it was lower than the plunger, thinking this would help prime it. After priming, the engine started normally. I really don't know what I did to correct the problem, unless I just didn't wait long enough for the primer to fill, when I first attempted to start the engine when we were in the water. Any suggestions would be helpful.
