Evinrude 20hp 1972 fuel pump problem
jiipeep
My Evinrude 1972 20hp fastwin doesnt run properly without manual pumping fuel to engine. It runs for 10-15 seconds after I pump fuel manually, and after that it runs in higher rmp and starts to caugh.
I ordered new fuel pump from boats.net but, it didnt solve the problem. I noticed that I have to blow very hard to get air going trough the pump. Is this normal or is pump broken?
With my -63 Sea King fuel pump motor runs fine:
http://flic.kr/p/9MVNHw
1946Zephyr
Re: Evinrude 20hp 1972 fuel pump problem
sounds like a fuel system clog. check every line and make sure nothing is clogged up.
jiipeep
I have checked lines and it works fine with my old -63 sea king fuel pump. So it is something wrong with that new pump?
jiipeep
Rebuild Kit 393088 doesnt have the part where are the valves. I have bought it and rebuilded the old pump, but it doesn work. Iboats pump is genuine Evinrude part. Does somebody have more succestions? :)
levi_tsk
Ensign
can you put the new pump on the seaking??try that if its a no go then the new pumps messed up
jiipeep
Maybe I solved the problem. I installed fuel pump so that output of pump is downwards. Now it seems to work. (it worked now 15minutes :) ) Before the line from fuel pump to carpuretor went upwards and fuel lines highest position was much higher than carpuretors bottom. Could this cause the problem? I hope so.
tx1961whaler
It could. Many pumps have a Top and a Bottom marking on them for that reason.
