Tunnelboat
- Joined
- Nov 19, 2008
- 3
I have a 1996 Evinrude 225 Vindicator that wants to bog when trying to accelerate. This is an intermittent problem and usually happens after the motor has been run 4 or 5 times that day. After setting in a fishing spot for an hour or so, I will start the motor and it idles good but when you try to throttle up it wants to bog down and die. If you pull the throttle back it will continue to idle smoothly, but when you try to accelerate it will bog down and die. Sometimes I have to try 4 or 5 times before the motor will accelerate and put the boat on plane. There are other times where I fish for 3 or 4 days with no problems at all. Once the motor accelerates and the boat goes on plane, the motor performs fine. I have totally drained the fuel tanks and put in fresh gas, replaced the fuel filter, changed the water fuel seperator, and installed new spark plugs.
Does anybody have any ideas or suggestions on what might be causing this problem?
