Hunter12345
Thread starter- Joined
- Mar 18, 2023
- 21
Good morning,
I have a 25 Evinrude E25TEECB. I am at a loss as to why I cant figure this out. Every time I take the boat out I have to spend 10 or 20 minutes re-adjusting the syncronization, low speed mixture, and idle screw. after I do that the motor seems to run fine. The next time Im out when i start it it will be misfiring, sneezing, or running extremely rough. I occasionally hear a knocking noise coming from the power head that sounds to me like pre ignition. I have the service manual and have followed the instructions exactly reguarding the sync. I have no problems at full speed except for occasionally it will take a longer than usual time to get on plane. I have done a lot of work on this motor, including; Rebuilt carb w/ carb kit, and float at correct height according to service manual, rebuilt fuel pump with new diaphrams and gaskets, new spark plugs, wires, and good coils with proper resistance, new power pack, new solenoid, and new battery cables. I have removed the flywheel to make sure nothing is installed incorrectly on the magneto.
Any advice will help a lot. Thanks
