flyingscott
- Joined
- Apr 8, 2014
- 8,339
ABSOLUTELY NOTThe trick to removing the carb without removing the starter is to use a cold chisel to remove the starboard carb nut. Make sure to use your cold chisel marks to install the nut correctly.
Now I've done it both ways but this saves you time. I mainly want people to do it "the long method" on here but one of the other problem solvers on here already disclosed that trick recently.
Two nuts, a few hoses and your off to the races.
