Evinrude 4.5 clogged tell tale
tgr23
Just getting an unused motor running after 10 years. The tell tale is clogged with some hard deposits. I've scraped out about 1/2" worth but it's still clogged and my tools can't reach anymore. How aggressive can I get with this? Run a drill bit up there? I've heard that there might be a grommet under the powerhead that might need to be checked. Thoughts? ideas?
Has a new water pump. Tried blowing air from the bottom up, no luck due to clog.
Thanks
Good Trout To You Sir
I'm interested in the answer to your question since I'm working to rehab a 1998 4HP that possibly has a blockage inside the overboard indicator. Is it OK to use compressed air to force air into the tell-tale (opposite direction of water flow)?
kbait
I’ve done that to stubborn 9.9/15’s to clear blockage..
