I have an old evinrude 4.5hp (suspect around 1975 model. I have removed the gearcasing to replace the impeller. When I removed the gearcase the drive shaft separated from the gearbox and not the crankshaft. I have since romoved the powerhead to get to the driveshaft at the crankcase end and cant find anything that should be stopping it from coming out of the crankcase housing. I have tried putting some force on the driveshaft to remove it, thinking that it may be corroded to the crank housing, but with no luck. Anybody got any ideas or ablke to let me know if there may be something holding the driveshaft into the crankcase housing?
