Evinrude 4
jakoolin
Hello , I a newbee on outboard motor and boating . I have an evinrude 4 model #E4RCCS it starts and run when in a bucket but when I tried it on the lake last weekend I put in on my inflatable boat it does not move forward. It makes all the bubbling in the water but does not do anything to push the boat forward. I posted in the inflatable section but was told this forum might help me better. Is there a clutch or lever to make it move forward? attached are some pics that I took to give you better information. thanks in advance.
Honorary Supreme Mariner
Re: Evinrude 4
I think your nuetral / forward shift lever is broken or missing.----Should be on the starboard side of the motor.
jakoolin
Re: Evinrude 4
Thanks everyone , I'll start with checking the shear pin first then compression at the same time look for that shift lever . I'll post back once I checked all of those. Anything else I need to check?
Xcusme
Re: Evinrude 4
Well,,if you get curious ...you can just check out the usual stuff like, the water impellor ect. If you find anything else, just post back here, there's someone to offer their two cents. You can always just order the OMC manual for yourself.
JRegier
Re: Evinrude 4
Oops. I didn't read it quite right. Agreed with drive pin or a spun prop.
Vic.S
Re: Evinrude 4
As said there should be a gear lever on the right hand side (your left as you look at it) This motor has forward and neutral but no reverse gear.
Check the prop dive pin but I think this one also has a rubber bushed drive which could have failed ... but they usually drive at low speed but then slip when you open up.
I dont think there is a cooling water tell tale so check that some water is blown out of the back-pressure relief port on the back of the exhaust housing below the clamp bracket.
Also check that it does not overheat.
If in doubt renew the water pump impeller.
Check/change the gear case oil. It should be "clear and bright". If it is milky, or there is water in the gear case, it indicates leaky seals which will have to be replaced
Fit new seals to the gearcase fill/drain and level plugs when you change the oil (O rings I think in this model)
If it starts easily and idles well I'd not suspect any compression problems but always worth a check esp if you have or can borrow a tester.
BTW the fuel mix is 50:1 gasoline:eek:il. Even if there are decals that say 100:1
The first thing you should do is get an owners manual. That will show you how it should all operate and the basic maintenance tasks.
