Re: evinrude 40 lark selectric shift HELP!
40773 is a 1967 40 HP.
For no spark, first thing I'd do is disconnect the "kill" wires that come off of the magneto plate if you have them (black ones, one of them goes to the vacuum cut out switch.
If still no spark, then pull the flywheel and check the points and coils. If the coils are original, they are likely cracked and fried. Instructions are in the "Top Secret" file at the top of the forum.
I check out things in this order:
--Compression. Cylinders should be within 10% of each other.
--For electric shifts, I make sure the motor shifts before going any further. It can get real expensive real quick if it doesn't shift. Need to use type C lower unit lube in these electric shifts.
--Spark. Use a spark tester. Should get a fat blue spark
--Carb. The fuel lines need to be changed out with ethanol resistant ones.
--Water Pump impeller
