Newbe15132
- Joined
- Sep 5, 2007
- 33
just so you know, This is the first time I even down anything with a outboard. I don't know anything about it. So, please keep it simple
The motor was sitting outside under a tarp for about 2 years. Once I got the electric shif to work, I taken it out. Ran fine put no power.
The next day, i seen some brown looking slugs stuff has dripped out on the ground. It came from the middle of the shaft, looks like 2 little holes there.
Well, that same day I taken it out, with a new fuel mixture 50:1. It seems to have alot more power, was able to rev it up higher. Now I get the boat to half power (or abit more) and start to open her up, evinrude will start to rev up fast and high rev. And I'm sure the boat starts to slow down. When I reduce the throttle, she kicks back in and the boat speeds back up. I must keep it under powered to keep it form slipping (or so it seems).
Then later on that day, when I started it up I thought I heard a knocking ot taking sound when I put it in fowered gear. I'll give her abit of gas (to be on the safe side) and hold it there, sounds like it going "Tap Tap Tap then start to pur, then I up the power and all is good.
One other thing, the gas house from the tank to the motor has a bad seel (on the engines side of the house) and leaks when priming. When motor is runing no leaking.
And theres the choke. I start the motor with choke on, when shes wormed up I'll attempt to put the choke to auto or off, then it'll die right out. Tryed the lean ritch nob, but not to much affect.
Then one more then I noticed, at the end of the ride, the motor kept stalling and I had to keep priming it to start and keep running, but that was only for the last 10 min, maybie a glitchs.
Hope all of this can help you pin point the main problem.
P.S on the lower unit I seen that there is one of them liqued gaskets around the unit. maybe its leaking?
Thanks,
Newbie15132
Thanks,
Newbie15132
