evinrude 40hp SPARK PROBLEM
wenham
How do i check the points and coil without taking the flywheel off<br /> The plugs appear to have a small spark on the block test No starteee<br /> is there a dea<br /> d switch or wire to connect that may be causing to trouble The outboard is not on the boat<br /> Ta
roscoe
Re: evinrude 40hp SPARK PROBLEM
Please be patient. It is 3 am in the US where most of the post are generated. You will probably get some responses within 8 hours, and even more in 16 hours. <br /><br />I'm sorry I can't help you with your question, but I am not familiar with your motor.
Joe Reeves
Wenham.... It would help if you listed the year of that 40hp engine. But at any rate, you will need to remove the flywheel in order to get at the ignition points. The spark on the magneto engines which I suspect yours is, should jump (with the s/plugs removed) a 1/4" gap with a strong blue flame.<br /><br />Keep in mind that the flywheel nut (if your engine is in the range of 1960 1970s) must be torqued to exactly 105 foot pounds. Anything less will result in having the flywheel key shear, causing damage to the flywheel and crankshaft tapers.
Joe Reeves
I just scrolled down and saw that you had another post where you did list the year as 1964. Your engine has a magneto setup and the flywheel nut torque is as stated 105 foot pounds.
wenham
Thanks JOE, The flywheel is there a secret in removing it, they are on pretty tight , im not sure if i have a proper puller :confused:
ob
wenham, You need to use a block type puller and utilize the tapped holes in flywheeel.This transfers the pull closer to the shaft.Tighten all block bolt to same height to insure straight pull. A jaw type puller only lips on the perimeter of flywheel and is like to cause breakage.
wenham
thanks you must be like rust you never Sleep haha :D
