I'm redoing the lower unit in this 'Rude 4hp,4636M,56008 . I have to replace the entire water pump housing, impeller etc, so I got the kit. I'm doing the gear case while I'm at it. <br /><br />Some rube had this apart and improperly installed the impeller and didn't fully engage the impeller pin. I suspect he ran it dry, the water pump housing melted!<br /><br />I have both the 76' OMC service manual and the parts list. Both of the lower unit seals, upper (under water pump) and lower (prop shaft ) are the same part 300599.<br /><br />I have 2 questions. First, I can't tell from the drawing which is up or down on the upper seal. Does the spring side of the seal go towards the gears or towards the water pump? . Since the seal I. D. is tapered, I'd guess the spring should go towards the gear housing so that the drive shaft won't snag on the lip upon re-assembly . Correct me if I'm wrong. The upper seal had the spring installed up when I took it apart and it didn't look right to me.<br /><br />Secondly, about the water pump assembly. The service manual shows what appears to be a nylon washer goes in the water pump cavity first, then a spacer with 2 bottom side projections, then the impeller housing cup.<br /><br />The parts manual does NOT show the nylon spacer, just the spacer with the bottom side projections and the impeller housing cup above that. The water pump kit I got didn't have this nylon washer either. Did Evinrude make a design change somewhere?? <br /><br />When I disassembled this puppy, the nylon washer was there but NO spacer with bottom side projections! That's probably why the impeller drive didn't engage the impeller. <br /><br />Should I re-use the old nylon washer or leave it out ( it's in good shape)<br /><br />Sorry for the long winded post, but I want to get this right. I just hate it when folks don't do the job right, leaving problems for the next guy.<br /><br />Thanks in advance for any words of wisdom and advise.
