Evinrude 4hp prop shear pin
loiner1965
1974 direct drive model with 3 blade plastic prop
The shear pin is only 12 mm long
It fits ok in prop and turns ok but it only protrudes around 1 mm either side of shaft
I ordered 2 pins from the correct part number for my engine and those are too long
Is my prop standard
Sea Rider
Re: Evinrude 4hp prop shear pin
If too long, could be filled down to proper lenght, as long diam is as required not an issue.
Happy Boating
loiner1965
done that just wondered if wrong prop....will check part number
Sea Rider
Small portables have some prop sizes to play with, probably was fitted with a prop that's not the one factory delivered. Probably a different prop to maximize other boating application ?
Happy Boating
