Evinrude 50 hp outboard lower unnit dropping
csisommout
I have Evinrude 50 hp that I try to lower unit to check the gear case because I ran over log. now motor vibrate when in gear, please tell me how to drop it. I unbolt it, it only dropped 1/4 inch lower. Thank you in advance,
Chris1956
Re: Evinrude 50 hp outboard lower unnit dropping
You likely need to disconnect the shift rod. They disconnect differently depending on the year of the motor. What year is it?
csisommout
Thank you for reply, don't the year but have s/s number G 02535055 and model # VE50BELESR. NOW WHEN I SHIFT GEAR IN FORDWARD IT DROP LITTLE MORE. BUT STILL DOES NOT COME DOWN LOW ENOUGH. THANK YOU.
csisommout
now, took out the L U and find out the shift rod slightly bent and the gear stuck at the neutral, can't push or pull by hands. can anybody tell me how to take the gear case apart or loosen the nuts after I removed prop. I am stuck, can't go further to inspect the shift fork. thank you in advance.
bonz_d
Check your other post on this.
