hello readers,<br />When I give full throttle the engine stops running. Half speed no problem.<br />What can be the problem??<br />The engine is from '94
Hello Den.....when the engine quits, does it spit, cough or sputter then die or does it just quit? If it coughs or sputters before dying, probably a fuel flow problem. How long have you had the engine and is this a new problem or did you inherit it? Have any idea on the maint back ground of the engine?
hello OBJ,he just quits. and when i start the engine again it runs.<br />I don't know the back ground of the engine.<br />I bought boat and engine in oktober 2004, so i used only a few times.
