Evinrude 50 HP VRO
hello readers,<br />When I give full throttle the engine stops running. Half speed no problem.<br />What can be the problem??<br />The engine is from '94
OBJ
Re: Evinrude 50 HP VRO
Hello Den.....when the engine quits, does it spit, cough or sputter then die or does it just quit? If it coughs or sputters before dying, probably a fuel flow problem. How long have you had the engine and is this a new problem or did you inherit it? Have any idea on the maint back ground of the engine?
Captain Jeff
I agree with OBJ, could be a fuel restriction. Check and clean your fuel filter. A common problem that only takes a few minutes to check.
hello OBJ,he just quits. and when i start the engine again it runs.<br />I don't know the back ground of the engine.<br />I bought boat and engine in oktober 2004, so i used only a few times.
