Evinrude 50 Wiring and Year
pjsteelejr
I need a internal wiring harness for a 50 hp Evinrude Mod. E50BELCLC Ser. J0001735 also what is the yr of this motor and where can I get the harness. The wires are breaking apart when you touch them. Can any one tell me why this is happening?
JB
Re: Evinrude 50 Wiring and Year
Problem with the model number, Fisher. If that last "L" is actually an "I" it is an '81.<br /><br />Wiring insulation can become brittle from too much heat for too long. When the wire inside is exposed to water, particularly salt water, it may corrode and become brittle. This shouldn't happen with marine grade wire because the individual strands of copper are tin plated.<br /><br />I would start my search for a harness, complete, here: http://www.boatmotors.com/parts/ <br /><br />If I had no luck I would try a JohnnyRude dealer.<br /><br />Last resort would be www.twincityoutboard.com<br /><br />No luck there I would make my own, using the old one as a model, and using only top grade marine wire.<br /><br />Good luck. :)
pjsteelejr
Will the 55 hp harness work? Can't seem to find one for a 50 hp 1981. Sent e-mails to used dealers waiting on reply.
OBJ
Yes, the harness from a 55hp will work.
