phillnjack2
Ensign
Thread starter- Joined
- Apr 30, 2011
- 918
Hello
First of all i will explain what is happening, and then hopefully someone might be able to help or give some usefull advice.
A friend has a 1987 50hp evinrude, it used to be vro but its now on premix with everything to do with vro taken of and discarded.
This engine has sat for about 3 to 4 years, and now its time to come back out and play.
So we put some fresh fuel in and fired it up.
Firstly we noticed that its spitting back fuel through both carbs and is misfiring a bit.
Secondly it seems very very smokey, even after running for 30 minutes.
The throttle linkage to stator seems very floppy, the stator bit it attaches too seems to be getting hit on each revolution due to flopping up and down. Is the plate meant to move vertically ? i know it has to move backwards and forwards etc to adjust the timing when at full throttle etc, but this seems a bit strange to me.
The fuel thats getting spat back from the carbs is a bit much, its more like its a back fire from the crankcase,just without the loud bang.
We ran the engine on muffs for about 15 minutes and it does seem to be revving up freely and starts pretty good.
There is a lot of blue smoke, infact it seems to be a hell of a lot to be honest.
When we put it in a test tank to see if water circulation from its own pump was good ,we noticed the water turning black very quickly with a lot of oil on top of the water.
It turned into a black oil mess very quick (tank has now been cleaned back out ready for any more testing)
we know the fuel is fresh and its 50-1 mix, as we done this just 20 mins before starting the engine.
The compression reads 155 on top piston and 153 on bottom piston.
Spark is very good on both cylinders as well.
The engine does sound to me like its missing a bit, could any of the following be the cause
does this sound like
1 stator problem (loose stator plate)
2 problem with reeds (reeds sticking open )
3 cylinder head gasket (we ruled this out when saw compression)
4 other electrical problem
5 carb problem
any help would be good as we hope to get this rigged up on my 13ft dory to test engine out on the river very soon
phill
5 carb problem
phill
