Evinrude 6 1997 Propeller shaft oil seal
Mikko
Could someone say which way this oil seal should be installed?
Crosbyman
can't say... I never saw a double sided spring seal
kind of 50-50 isn't it I hope the spring steel is stainless otherwise it will rust away eventually
the inside one will soak in oil :)
Mikko
I almost see that the protruding spring lip of seal (2) is pointing the propeller :cool:
