Tim Frank
Thread starter- Joined
- Jul 29, 2008
- 5,354
Doing some maintenance on a 6 HP E/rude, 1975 model.
I have had this motor for ~ 15 years has always run really well...last year not as well. The motor got "drowned " a couple of years ago and while drying out the ignition (flywheel off) I noticed that the coils looked "iffy" and so I put them on the do-soon list.
Compression is 90 PSI top and bottom.
So this spring got a whack of parts from iBoats (they were great to deal with):
1) Changing entire set of ignition components...coils, points, condensers ....no problem with this, but I created a real problem for myself with the flywheel key.
First question ....is 1/16" enough of the key to be showing above crankshaft taper?
It looked way too small to me ~ I did not measure, but it would have been no more than 1/2 the depth of the keyway cut in the flywheel....so I decided that I'd get a new one and tried to get the old one out....it doesn't want to budge with the force I have used so far....I have a fairly light hand learned from the times when I have used too big a hammer..
I have chewed the key up enough that I would not be comfortable reassembling with the old key. Obviously this is entirely self-inflicted...since with a bit more thought I would have accepted that the motor ran fine as it was, so I should have left sleeping dogs lie....but I didn't.
:facepalm:
The crankshaft taper is pristine and there is nothing that looks odd...that the original owner might have done....glue or adhesive of some kind. So I am not sure why it might be locked in there.
So....any tricks on removing a stuck flywheel key?
Are they hardened?....or might it be soft enough that I could drill and tap for a small machine screw and pull it out with that?
2) Carb....The carb kit that i got from iboats has a few extra parts...including an assortment of carb-manifold gaskets and fibre washers.
The problem I have is with the low speed jet packing installation. When i took out the low speed jet there was a plastic washer and "some" packing behind it.
The kit shows the assembly as (from the inside out) 1- Needle valve packing, 1- needle valve packing washer, and the packing nut.
They do not include a packing nut, obviously you reuse the original brass one....and there was nothing in the kit that could have been the packing washer so I reused the old one with one packing
The OEM manual that I have shows just two packings...and the packing nut...no washer...
The parts list at "shop2.evinrude" shows two packing + the washer and then the nut.
Anybody got any suggestions on what is correct?
I have installed lots of these over the years and it all feels fine...loosen the packing nut a bit and the needle valve turns easily....tighten it down and the NV gets hard to turn.
It may not really matter, but it seems odd that the 3 references would all be different.
