Evinrude 60hp 1995, realy getting me down now...HELP NEEDED
phillnjack2
Ensign
Hello everyone
I have a Evinrude 60hp 3 cylinder,1995 model and i think its been cursed by a DEMON who hates water.
Model no BE60TLEOC
Serial no G 03751787
My latest problem is driving me nuts.
I disconnected the vro as soon as i got the engine to be on the safe side and use pre-mix at 50-1.
The engine ran fine in a water butt for about 30 minutes, was then stopped and put away for a couple of weeks.
Next i got a brand new tank and fuel line, to make sure ive got no fuel line problems, as i dont know the age of the old ones.
Now on last sunday i take the boat to the river, it starts fine and idles for a couple of minutes then dies :eek:
I pump the bulb and it runs again fine for a few minutes then dies :(
Ok so i pump the fuel bulb again, and this time rev it up and take boat for a ride, i have to keep pumping the bulb to
keep it running but do this for about an hour. ( no going home without enjoying a boat ride)
Once back home i take off the VRO fuel pump and completely strip it down and find nothing seems to be wrong with it.
I make 100% sure its nice and clean, and re-fit to engine.
Today i get boat out of garage put engine in water butt and fire it up.
It runs fine, but again only for a few mins then dies unless i pump the bulb :confused:
I have checked compression a few weeks back and all cylinders are good with 145. 147,145 psi.
checked again today and all cylinds still giving same figures.
Fuel is fresh and clean,oil is also fresh, i use quicksilver 2 stroke oil, fuel tank new, fuel line and bulb new.
I took the fitting of the fuel line and connected it direct to the engine fuel filter as well so as to eliminate the
fitting from engine to tank etc.
The disconnected oil side of the VRO is plugged and NO air is getting in there.
the pulse nipple on the engine was taken off and cleaned to make sure its not got any blockage etc.
what am i forgetting to check ?
i cant think of anything else to try ?
I do have another VRO pump from same year engine,ive put this on and that gives exactly the
same results as original in that it dies after a few minutes !!!!!!!!!!!!!!!!!!!!!
This evinrude is realy getting at me, ive not had issues like this that ive not been able to simply fix in the past.
im getting so old that im missing stuff that is obvious to those who know !!!
Please help, advise me,
phill ....:mad:
retiredfornow
Re: Evinrude 60hp 1995, realy getting me down now...HELP NEEDED
Sounds like a bad fuel pump. You can get a non-VRO pulse pump for 50-60 bucks. That's what I'd try next. Good luck.
phillnjack2
Ensign
im gonna see if i can borrow my friends non vro pump off his 50 to give it a try.
if it works ok ill buy one of those and rig it up.
seems very strange that 2 identical pumps have gone bad at same time.
sasada
Hmmmm...tough one. Sounds like you are doing the right things. I have heard that you need to use a non VRO pump if you disconnect the VRO for if you dont the VRO pump (that is meant to pump BOTH the oil and gas) will go bad since the diaphram inside will dry out from not pumping any oil. Now if that is true or not im not sure....
PS...let is know what you find!
phillnjack2
Ensign
My friend has took the ordinary fuel pump off his engine tonight for me to try on my engine :eek:..
We know his pump is very good and strong :p
Tommorow ill take off the vro completely and put the old style non vro pump on and see what happens.:confused:
Im hoping this is the problem, if it is ill just get a new pump for it:).
or it could mean i have a leaky crankcase somewhere or possibly
even a broken or weak reed valve.:confused:
Does anyone know what vacum the 60hp should be ?
boobie
You can also get a fuel side only rebuild kit at Maxrules.com.
phillnjack2
Ensign
Well ive tried the old type of fuel pump and it seems to be running good in the water butt.
With the VRO pump it would only run for about 3 minutes then die if i didnt squeeze the bulb to keep running.
With the old style ordinary fuel pump its been running for 35 minutes no problem.
I will try it out on the river to make sure it pumps enough fuel at full throttle etc.
if its good then ill get a new one of these pumps or a good secondhand one and a new pump kit.
The VRO repair kits seem very expensive to do the same job.
