Evinrude 6hp carb reassembly/installation - gasket sealant?
ncpi
I am rebuilding a carb for a '73 Evinrude 6hp. I checked the top secret file, but no mention that I could find of whether or not to use gasket sealant on the carb gaskets. Do I use sealant? If so, what type is recommended?
Thanks!
OptsyEagle
Re: Evinrude 6hp carb reassembly/installation - gasket sealant?
Do not use any sealants on the carburetor. They can get into the jets and your are right back to where you started ... a dirty carb. All carb gaskets should go on dry.
nwcove
no sealant on carb/intake gaskets. just make sure all mating surfaces are clean and dry.
ncpi
Thanks!
