Evinrude 70HP Part Number?
brendanp
Does anyone know the part number, Sierra or otherwise for the S shaped metal plate that is screwed on top of the throttle and gear cables to keep then in place on the engine block and the screw as well. I lost mine the other day when I was adjusting the cables. Thanks guys.
ezeke
Re: Evinrude 70HP Part Number?
That will depend on the year. Navigate to your motor at the brp parts catalog site, then open the cylinder and crankcase diagram. Click the number of the part you want and it will take you to the line item and part number.
http://epc.brp.com/default.aspx?brands=ej&lang=e
tashasdaddy
i just found a bolt that fit, took a piece of flat stock aluminum and drilled a hole in it. has work fine ever since.
brendanp
Cheers chaps got the part number it is 0319967, anyone know if Seirra do this part? Think I will do the ally trich as tashdayy said not worth the ?15 odd quid they will charge me for the part. Thanks for fast response
