Evinrude 75 hp Model # 75743 Sport
Tboner7864
Hey Guys just checked out this outboard and checked the compression it has 140 in all three cylinders. Is this a good motor? I see it was made for the salt water but I don't think it was ever in salt water. and does anybody know if it is a 2 stroke or a four stroke engine? Any info on this motor would be helpful thanks
Tbone
boobie
Re: Evinrude 75 hp Model # 75743 Sport
It's a 2 stroke and the compression sounds real good and it's a good motor.
Tboner7864
Thanks boobie, so for $200 is a good deal? Does anybody have a PDF manual for this motor?
boobie
Are you getting the controls with it too ??
Tboner7864
Yes the controls come with it I will be able to unhook everything and take it right off the boat with ease, I also get the fuel tank
geoffwga1
For that price you better not mention where it is or you'll get trampled in the rush.LOL.
Chinewalker
Run it like you stole it! Good motor and you got a good price on it. Compression numbers are very good. Make sure it gets propped to fit whatever you put it on, .ie the motor is allowed to spin upwards of 5500 RPM at WOT. Lugging it will kill it in short order...
Tboner7864
Thanks Guys I already made the deal it is going on my little bayliner capri 14ft so I don't think it will lug at all it is a little bigger than the 50 hp Force I had on there It is only a little heavier about 72 pounds. I guess the force 50 was 150lbs and the Evinrude 75 is about 222lbs
Tboner7864
So does anybody know where I can get a pdf manual for this motor
Tboner7864
Hey guys alright I got the motor on my boat replaced some gas lines put new water pump but I would like to install a Tell tail how do I go about doing this on this motor and what parts do I need saw someone on youtube did this to this exact motor but they did not explain just showed it any information would be helpful and by the way it fired right up and Idled after sitting for years unbelievable
