Re: Evinrude 75 - Please Help
Well, you got it all the way to the 2-yard-line and stepped out of bounds. C'mon, push it on into the end zone!
Running on the muffs, the motor is completely unloaded. It'll run all day on 2 cylinders and sound happy doing it, then crap out when you put a load on it.
This is really not the least bit surprising. Remember how I said "rebuild the carbs now anyway, just on general principle"?
Don't be discouraged, though, we all learned the hard way...the carbs can not be cleaned without disassembly. Seafoam is great stuff, I add it to my fuel, but the fact is, anything strong enough to clean your carburetors will burn a 2-stroke engine up if you try to run it in the gas tank.
So, the carbs have not been cleaned, and regardless of how they may seem, the gaskets may or may not be in good condition -- you just can't eyeball 'em and tell.
Very unlikely to be the fuel pump...see #7 above, if the line's holding pressure, the pump's ok. If it's not holding pressure the pump is still probably ok. If there's fuel leaking out of that hole on the backside of the pump housing, the fuel pump needs a rebuild.
Don't be intimidated, these carbs are amazingly simple devices -- you'll be very happy with the result. I promise.
[btw, revving it up on the muffs, very risky. search this forum for "thermal runaway"]
