evinrude 75hp sport
shawn.54
what differenae does sport make and is there any major bugs with them?
jimmbo
Re: evinrude 75hp sport
During the late 1970s early 1980s OMC produced a 75hp based on the 49.7 cubic inch 3 cylinder block. The extra 5 hp from the usual 70hp were from slight porting changes and a higher compression cylinder head. It put out a bit more top end power but it was weaker in bottom torque. It was putting out 1.5 hp per cubic inch. The only other motor that did that was Mercurys 150hp inline six.
shawn.54
is this a poor choice then if skiing and tubing are what i am gettimg this boat for?
shawn.54
this motor is on a starcraft 15.5 foot trihaul that a co worker has. He said boat was 78 but motor was 79 or 80. I dont have numbers yet.
boobie
You don't want the 75 for skiing or tubing. Poor hole shot, unless you want to play arond with props. Been there.
shawn.54
this boat being given to me if a reprop is all i have in it that is not to bad. only thing that scares me is that it has not run in 10 to 12 years. was fogged when put away but that is a long time.
Chinewalker
The 75 will be fine for tubing, etc. Just prop it accordingly. I have a 1980 75 Johnson (same as the Evinrude) on my 15-footer and it does the job, even with my 240 lb. brother in law. Hole shot is fine.
The "Sport" name was a paint and graphics package on those models. Nothing more.
