I need to know where the 4 cylinder ignition wires go to the four distributor fittings for such wires. there are 2 distributor fittings forward of(would pass a point on the block on a clockwise rotation of the distributor head) the lead from the coil to the distributor and 2 fittings aft of the coil wire port. put another way, where do each of the wires from the cylinders 1,2,3 and 4 go on the 4 fittings on the distributor as above described (let's say "a" is fartherest in advance of the coil lead, "b" is next, the coil lead, "c" is to the rear of the coil lead, and "d" is the final fitting).
