evinrude 85hp
tooler1
hi i have an evinrude 85hp shortshaft what distance
below the transom should the prop be for a good
performance , Hope this made sense thanks
ezeke
Re: evinrude 85hp
The anti-ventilation plate, which is the horizontal plate that is just above the propeller, should be at least even with the bottom of the boat if not a liitle higher. When cruising, the A/V plate should be level.
tooler1
Re: evinrude 85hp
thank's for that info what would happen if
it was'nt at the right level,ie to high
ezeke
Re: evinrude 85hp
Depends on how high. If you have it on a jack plate, you can go quite a bit higher.
Steering changes with the height, but there are some performance advantages.
What is the year of your motor? I am most familiar with the early series in the 1970s.
JB
Re: evinrude 85hp
Bad idea to post two different questions with the same topic title, tooler. You almost got this one deleted as a double post.
