First let me say this forum is awesome! I only discovered it a few days ago and already it has been tons of help.
I'm working on an 1987 30hp Evinrude model # E30RCUB. I can't get the motor running. The only history I know is that it has not run in over a year. I've already checked the standard things (good spark, fresh fuel, etc). Figured cleaning the carb would be next. I found some disturbing damage inside.
First, there is a chunk of metal missing from the edge of the screw slot of the orifice plug in the float bowl. The orifice itself appears ok but I doubt I'll be able to back the orifice out with the screw slot damage...
Second, and appearing more serious, is the crack on the main nozzle (or venturi tube, whatever it's called). The tube is bent slightly out of round like it was grabbed with pliers and has a crack running almost all the way to where the tube passes into the main carb body.
So, could these be causing my no start? Can the tube be replaced? I don't think so but I'm hoping... If my carb is trashed what model years and/or HP's could I use as a replacement? Where would be a good place to look to get one? The only place I've found them is from Evinrude for about $300!! Anyway, thanks in advance for the help!
Kyle
Kyle
