DeepCMark58A
- Joined
- Aug 17, 2015
- 2,592
So had the motor laying around the garage decided to mount it on the jon boat. I cleaned up the spark plugs cleaned up the carbs and the motor starts and runs. I put the boat in the water and the motor does not come up to speed. I did some testing and the bottom cylinder has no spark. I understand a coil failure is pretty common. I have a question I need to pull the flywheel. The nut on top needs to be removed do the 3 screws as well? Also does the flywheel need to be aligned to the exact position it was when I remove it?
