mechanic136
Thread starter- Joined
- Nov 21, 2010
- 11
I have a 1974-76 9.9 evinrude(Model number plate missing).Can only keep engine running if I move throttle plate beyond where it sits at the start position.The carb roller is contacting the timing plate mark but does not open the throttle any further. There does not appear to be an adjustment on the cam follower. Should I bent the linkage rod or does the timing plate need to be moved?
Thanks
Thanks
