Thanks. I did put up above the engine still the same issue. Will try to test engine pulse port next. Spark plugs are little black when I pulled them out.I restarted and keep pumping the bulb than it keeps running.
hand pump it again and make certain the tank is ABOVE the engine
try to start it...
if it runs the pump is faulty install a new one . (up to you $$ ) The only reason the pump would not work is that the crankcase pressure pulse on the cyl downstroke is not reaching or strong enough to work the pump.
remove the pump as a test and put your finger on the engine pulse port
have a buddy crank the engine ...you should feel the air pulsing. if not crankcase is loosing back pressure.. could be bad reeds or crankcase seals which I doubt.
other opinons welcome ! and by the way did you confirm you have good strong sparks on both plugs what compression #s did you get
I don't have marine battery but the car battery. I can just touch +ve and -ve it will start?btw you have electric start ... why not hook up a battery and get it going.
very basic circuitry find the solenoid and follow the small control wire to the start switch !
basic for 1984 should be similar to yours even if earlier model.
yellow red to solenoid should activate the solenoid the rest is for charging the battery and firing the coils so focus on the solenoid-starter
I bought new bulb but not the hose.Have you tried a different fuel hose?
I will check. ThanksAnother thought. When you cleaned the carb did you put the little clip on the inlet valve to the float.
Sometimes those inlet valves can stick and they came up with that little clip to make sure the inlet valve will get pulled out of that passage way to allow more fuel to enter the carb as the float drops from fuel usage.
