evinrude 90hp 1985
fishandhunt
hydrolics lifting motor up it is straining to lift past half way, sticking going down makes strange bubley noise going down,i hav put greese everywhere and in every nipple i can find please help.could it be oil level and how do i check this?
will62
Re: evinrude 90hp 1985
Turn your manual release screw out about 1.5 turns. Manually lift motor and engage trail lock so that you can access the reservoir fill screw. Remove the screw, and add fluid (atf ok) until it reaches the level of the screw opening. Replace fill screw. Flip back trail lock, and raise and lower motor about 5 times to clear air from the system. Repeat the process until the fluid level no longer drops.
